6th Gen ('00-'05): Heated Seats
Old Nov 29, 2013 | 10:33 AM
Brotan3's Avatar
Default Heated Seats
I have only one problem with my MC, and it's that my heated seats don't work. When I hit the switch the light will turn on but no heat. Can someone tell me what the problem may be and the difficulty of the repair. Thanks
Old Nov 29, 2013 | 10:45 AM
Most likely there is just a problem with the wiring, they can sometimes burn out.
You would have to remove the center console, and maybe even the wrapping on the seat
Old Nov 29, 2013 | 10:46 AM
Thumbs up
Hi Brotan3, and Welcome to the MCF
What year is your Monte Carlo ?
Check the below links & check back to see what are Expert Tech's post on your problem > Good Luck
Heated seat not working - Monte Carlo Forum - Monte Carlo ...
montecarloforum.com › ... › General ForumsGeneral Tech
Sep 10, 2010 - 5 posts - ‎4 authors
My drivers side leather seat heater is not working. I followed the write up in the heated seat fix, but I don't have a burnt wire problem. I believe.Driver Side Heated Power Seat Problem. - Monte Carlo ...
Aug 18, 2011
heated seat issue (driver side)
Nov 16, 2010
Heated seat fix.
Jan 24, 2010
Heated Seats diagnosis Procedure
Jan 18, 2010
More results from montecarloforum.com
seawolf18
Nov 10, 2013 10:23 AM
MrChyes
22
Jul 24, 2011 10:59 PM
SolowSS
Mar 19, 2009 07:41 PM
dustybird3
Apr 25, 2008 08:56 PM
phlyx
Dec 16, 2005 02:10 AM
