Heated seat not working
Old Sep 10, 2010 | 09:41 PM
seawolf18's Avatar
Default Heated seat not working
My drivers side leather seat heater is not working. I followed the write up in the heated seat fix, but I don't have a burnt wire problem. I believe the bottom element is just shot. I heard from some where that you can bypass it so only the lumbar heater would work.
What wires need to be connected together to make it work? I would like to get one of them working before winter hits. Winters here get really really cold. Thanks.
Old Sep 10, 2010 | 11:29 PM
wow, I don't know the fix for that but it is a total bummer j/k man, someone here has got to have a fix for it...
Old Sep 11, 2010 | 11:11 AM
reality1's Avatar
Just buy a new element and have uphostery shop install. Corvette forum has several online sources for GM Parts.
Jim
Old Sep 11, 2010 | 02:39 PM
wnmech's Avatar
I am looking at a wiring print of the heated seat. There shows to be a relay also called the control module for the drivers seat and also a relay for the passengers seat heat. It appears to be mounted under the seat. You may also ohm out the elements to make sure there is not an open in them.
Old Sep 13, 2010 | 04:18 PM
JaxJim's Avatar
The leather seat in my car is hot as hell. It was 92 degrees in FLA yesterday. I need a seat cooler.
Tiger Joe
Dec 19, 2024 04:15 PM
Leprechaun93
Nov 16, 2013 11:22 AM
frankv3
Nov 10, 2013 10:22 AM
KyleScottAdams
Oct 14, 2010 11:38 AM
jimbo7
Dec 3, 2009 03:05 PM
