Halo lights not working
Old Nov 1, 2009 | 09:23 PM
bigmichaelcool's Avatar
Default Halo lights not working
The right side halo lights stopped working; not the headlights; just the halo and amber signal bulb. Has anyone else experienced this. I have had the lights for a little over a year. I havent had the chance to check all of the wiring as I just noticed this after washing the car this evening and it was getting dark. The drivers side is working just fine! Any suggestions?
Thanks!!!
Old Nov 2, 2009 | 07:45 AM
Enzo354's Avatar
STILL SLOW
Double check on any wiring, then check if they have a lifetime warranty...
Old Nov 7, 2009 | 02:12 PM
After some trial and errors Ive come to the conclusion that there is a problem with the halo ring lights. With the halo lights disconnected, the side and parking lights work just fine.
Does anyone know if the light assembly can be opened to check the wiring inside the light cluster? I dont see anything wrong with the wiring on the outside. Thanks for any info!!
Mike
Old Nov 20, 2009 | 08:49 PM
I contacted the seller of the lights and described my problem. After some trial and error suggestions from the seller; they sent me two brand new transformers at no cost to me; not even a shipping charge. I installed the new transformers on both light assemblies and all works just fine! In fact the halos look to be brighter than before!
If your halos quit working and blows a fuse; check the transformer boxes and contact the seller. I purchased mine from Revotec and they are easy to deal with.
Old Nov 23, 2009 | 11:00 AM
RickAKATed10's Avatar
Photobucket
Thanks for the update.
trav
Mar 29, 2022 08:56 PM
KingOf206
Dec 25, 2013 07:12 AM
cornerview
Sep 17, 2010 02:49 AM
RickAKATed10
Jan 23, 2009 10:38 AM
thedude
Sep 1, 2006 10:26 PM
