Relocation harness for 04 MC
Old Nov 22, 2009 | 05:13 PM
04MonteLS's Avatar
Default Relocation harness for 04 MC
I have pulled my deck out and put my stock deck back in cause I had alot of problems arise after I installed my system. I'm assuming it's because I left the amp plug disconnected at the deck since the interface I used didn't have a connection for it. I have concluded that I'd much rather leave the factory deck installed than deal with these hassles again so I want to fiberglass the deck into the open area in front of the shifter and below the heat/ac controls.
This accomplishes two things, leaves the factory deck in the loop so all class 2 communications are left intact and also provides some stealthness to the install since when someone's walking past and looks in they'll see the factory deck and hopefully will keep walking.
But in order to so this I need to get ahold of a relocation harness so does anyone know which one I will need? How does it work?
Old Nov 22, 2009 | 08:20 PM
Dbl_D718's Avatar
What were the problems you were having? My factory amp and anything associated with it is unconnected and I've never had any problems.
Old Nov 23, 2009 | 09:11 PM
04MonteLS's Avatar
So do you know what relocation harness I'd need?
Old Nov 24, 2009 | 12:40 AM
04MonteLS's Avatar
Found it!
MonteLSV6
Aug 27, 2010 07:52 AM
dirty mech
Jul 17, 2010 10:05 AM
7801MonteMan
Feb 20, 2010 01:24 PM
mrl390
Apr 11, 2009 09:27 PM
roadshoptuner
Jul 30, 2006 09:54 AM
