Good Aftermarket rear speakers
Old Jul 19, 2012 | 09:50 AM
Originally Posted by 03SSLE
I beg to differ.
There's been numerous people running other 2 ohm speakers that have bad results alson its not usually the ohm rating that throws people off its the rms wattage and the stock headunit or amp doesn't have enough power for most aftermarket speakers. Hence why the stock ones are cheap and paper, they don't need to be very heavy duty to handle that little of power.
Old Jul 19, 2012 | 01:21 PM
RonBoySS's Avatar
The speakers are in, $429.90 shipped from sonic electronics.com, if you can swing it you will be very happy with JL speakers. If you need to get by for a bit let me know.
Old Jul 19, 2012 | 03:47 PM
03SSLE's Avatar
I understand completely where you're coming from...I've read a lot of the complaints also. I really do think though that a lot of it has to do with speaker selection and improper wiring. When I first installed my Infinity speakers they sounded terrible...very little volume and hardly any bass response at all. I was actually tempted to take them out and put the factory speakers back in. Instead I decided to double check my wiring. I found that 1 speaker was wired correctly but the other was wired backwards. I switched the wires around on that speaker and they literally came to life. The bass response is very clean (not muddy like the factory speakers) and volume is not a problem. The front/rear balance control on my radio has 3 clicks of adjustment when centered. I used to run it in the middle (1 click of adjustment of either side) with the factory rear speakers. With the Infinity speakers I turned it 1 click towards the rear (but the indicator still shows them as being centered) to obtain the same front/rear balance that I had with the factory rear speakers. Having the speakers wired properly made all the difference in the world as to how they sound. If I hadn't decided to double check the wiring I would be on the same bandwagon you're on telling others how crappy aftermarket speakers sound with the factory amp. All I can say is these speakers sound 1000% better then the factory speakers did.
Old Jul 19, 2012 | 05:37 PM
That could be the problem, but I've wired some correctly that still didn't sound good.
I like my Kickers powered by my f300, they're nice and loud when I need them to be :p
and.i.crawl
Oct 30, 2013 03:44 AM
sisson16
Nov 29, 2012 10:36 PM
DenaliZO6
13
Feb 25, 2012 10:01 PM
ChevyWhirlwind
40
Oct 13, 2010 12:49 AM
swanny09
Oct 1, 2009 09:13 PM
