GM Factory Integration Adapter
Old Jul 1, 2007 | 12:45 AM
Ndizzle428's Avatar
Default GM Factory Integration Adapter
what will happen if i dont install the GM Intergration Adapter to my headunit? im not worried about my chimes but i was told it would get rid of my warnings and i dont have onstar so im not worried about that either...i just dont want to spend over a $100 for an adapter but will if i have too
Old Jul 1, 2007 | 04:35 AM
ExplosiveSoundz's Avatar
Default RE: GM Factory Integration Adapter
Crutchfield recommends the following:
You must use the recommended Crutchfield integration adapter to retain the warning system chimes. Failure to do so may result in serious injury or death.
Not to mention I have actually heard of a few cases in newer cars where the people that replaced their head unit and didn't install the audible warning system interface was NOT able to SUE in an accident that they were in, due to negligence on their part.
I have also heard that certain insurance companies will not compensate if you compromise any of the factory security/safety settings if you are in an accident that requires an accident investigation report.
You may want to just spend the extra 99.99 and not take any chances. Especially in dangerous driving conditions.
Old Jul 1, 2007 | 04:43 AM
Also, the traction active and traction off, in addition to other warnings on your message center will not be able to be heard.
Old Jul 1, 2007 | 09:17 AM
DeboDaddy's Avatar
Everything said above is true, however, When I did my install on my 2000 SS a couple weeks ago, I did not use the factory integration adaptor. When you do not use it, there are 4 wires than stay un-wired from the factory harness. So far, my stereo works perfect, I have no chimes (yay), but all my dash lights still work, and everything else seems just dandy.
I have to admit, halfway through the install I was wishing I had bought the adaptor. I actually had one wire hooked into power that shouldn't have been, and this would not let me even start my car, and the security light in my dash was flashing non-stop. But I just probed for the problem and voila! Fixed.
[/align]
Old Jul 1, 2007 | 10:42 AM
Ndizzle428's Avatar
iight thank you
Old Jul 7, 2007 | 06:20 PM
drayven's Avatar
Where could I get this adapter? I am considering changing my stereo to aftermarket but an unsure where to get this adapter.
Thanks
Peter
Old Jul 7, 2007 | 07:25 PM
Bigg J's Avatar
Usually any retailer who sells quality aftermarket radios (I'm not talking about Jensen radios at Walmart, people!) will have the adapters for sale as well. Crutchfield.com has them, your local stereo shop, etc.
Old Jul 8, 2007 | 07:18 PM
drayven's Avatar
What are you talking about...Jensen stereos rock! lol :P
Cheezburglar
Oct 30, 2012 04:53 AM
Darius Lovehall
May 21, 2011 07:09 AM
PostRelease
Jun 1, 2010 12:18 PM
pfugly
Apr 6, 2010 06:40 PM
smyurick
Jul 30, 2007 07:18 AM
