front component install help
Old Mar 24, 2009 | 09:57 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Default front component install help
could anybody guide me through a front speaker install? i have a component system i want to install, and cant figure out a good spot to put the tweeter at, and also.......i've never removed a door panel so if somebody could help me out with how to? i wanna do it all this thursday, they've just been sitting in my garage waiting for me to install.
thanks in advance
Old Mar 28, 2009 | 05:43 PM
Photobucket
Bump...
Old Mar 28, 2009 | 07:00 PM
RocknSS04's Avatar
Old Mar 29, 2009 | 10:37 PM
jaws2008's Avatar
GOT SPL
to remove door panel...
-remove screw in sail panel and the door handle that opens door.
-pop out the piece around the door handle.
-under the arm rest part of the door were the handle is there is 2 TORX 30 screws remove them
-pry out the clips that attach door to frame( use something like a flat screwdriver to get between panel and frame, better yet use the door panel tool.).
-lift and remove door.
-Remove speaker, speakers are attached by TORX 15 screws
-attach door panel on in backwards step order(make sure that when door panel gets put back on slide the door panel down on to frame so the little clips at the window are attached properly or it wont attach right Hence when removing lift up and pull).
-good luck
Old Mar 29, 2009 | 11:01 PM
red03ssmonte's Avatar
In my oldest car I had them right on the inside of I think its called the A pillar. I think I may do the same thing in the monte its nice to have the tweeters close to your head imo makes ur music seem so much more crisp.
Old Mar 29, 2009 | 11:48 PM
Photobucket
thanks for the help guys, when in install the components im gonna do some interior painting too, hopefully i'll get a chance tuesday to do it all.
Old Mar 30, 2009 | 08:35 AM
A note to when jaws was telling you how to take the door off.
He is saying LIFT the door, because there are metal clips that hang at the top near the window, be gentle with those. When you pop all the clips around the bottom off, try not to put too much pressure on the door, because those clips are all that's holding it on.
Old Mar 30, 2009 | 08:52 AM
jaws2008's Avatar
GOT SPL
Also be careful when removing the switch things like the lock and and the window roll down thing. the quick release on harness is not accessible because it faces the door panel so you kinda need to pull out the whole unit and its really really easy to **** it up.
My first time i had actually pulled the hole unit apart but was able to successfully put it back together to make it work.
Shandley
FWD Tech Guides '95-'07
Oct 21, 2019 09:02 PM
Bxbootlegger
21
Sep 5, 2012 09:20 AM
montecarlolt
Jul 23, 2007 06:52 PM
