FOG LIGHTS
Old Oct 17, 2008 | 03:29 PM
xkylex's Avatar
Default FOG LIGHTS
Hey guys, I have a 03 monte carlo ls, and it has two spots for fog lights but there is just plastic covering the holes (see picture). Do you guys know of any site where I can get fog lights that will fit perfectly. Thanks a lot.
Old Oct 17, 2008 | 03:32 PM
mickey's Avatar
Default RE: FOG LIGHTS
do some digging here on the topic of fog lights. I can not remeber off the top of my head but there was a member that recently put fog lights in his/her car and they were a factory set up.
as far as i knwo those are about the only ones that will fit the car perfectly most come close but dont look right to me anyway.
Old Oct 17, 2008 | 03:35 PM
xkylex's Avatar
thanks a lot, ill look into it
Old Oct 26, 2008 | 06:57 PM
jzeiger07's Avatar
i recently bought some foglights off ebay called "bling lights", just 15 L.E.D.'s (they come in many colors) which were a tight fit but very easy to wire up
Old Oct 27, 2008 | 03:31 PM
04 Intimidator's Avatar
Junk yard is always a good sight for parts.
Old Nov 1, 2008 | 11:16 AM
xkylex's Avatar
Thanks a lot! Finally found some!
Old Nov 1, 2008 | 01:48 PM
RickCoMatic's Avatar
I got mine from a Salvage Yard. You need the Lights AND Mounting Frames. Without the Mounting Frames they're worthless. It's all about those Mounting Frames to get lights behind those Oval Cut-outs and not have to bastardize the Bumper.
The OEM Mounting Frames are a tripod configuration and fit slots and keys behind the Bumper.
The single Fastener secures the whole mount through the Pre-drilled hole in the Bumper.
Cars with Louvers and NO Lights are NOT wired for Fog Lights. You'll have to fabricate your own wiring harness, relays and switching and run them off the Battery and the Aux Fuse at the drivers side Fuse Panel. Power for the Lights can be rum from a HOT Terminal on the Power Distribution Panel. Power for energizing the RELAY needed to have the FOG Lights turn off with the Ignition comes from the Fuse Panel.
The easiest way to run a wire to the Fuse Panel from under the Hood is to remove the Radiator Overflow Tank and drill a hole through the Firewall.
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
mickey
Jun 29, 2005 11:40 AM
