Flasher issues
Old Oct 21, 2023 | 10:25 AM
Patches@2009's Avatar
Unhappy Flasher issues
I have an 05 monte carlo ls that has a turn signal/flasher issue. My turn signals work when my car is in park, but when I put it into gear, the emer. flashers and turn signals stop working. I replace the flasher switch and still no luck. Anyone else run into this problem?
Old Oct 22, 2023 | 07:44 PM
This sounds very strange. First time I have heard of this topic. I know the turn signals and the 4-ways all get controlled via that flasher module/hazard button. This is implying GM changes the circuit based on what gear the car is in, which strikes me as very strange. Was anything changed in the car? Stereo equipment? Anything at the time this issue began?
Old Oct 23, 2023 | 07:14 AM
I replaced the stereo with an Alpine system 3 years ago. Started diagnosing the fuse-box yesterday as my cig lighter also does not work. No power going to fuse panel on drivers side panel. Will go over wiring diagram later today
Old Dec 17, 2023 | 10:01 AM
So I took the car to my local shop and they found a corroded ground inside the dash. Re-did the ground wire and eveythimg works as it should.
Old Dec 17, 2023 | 10:08 AM
Thanks for the follow up! That could NOT be easy to find. Great work by your local shop!
Old Dec 17, 2023 | 09:50 PM
it took them 5 hours to figure it out. ground was good untill the bcm put a load on the lights.
romanowski
Aug 25, 2023 02:57 PM
SteveQ
Oct 3, 2019 01:44 PM
Barbie
Jun 17, 2019 09:09 PM
Mcvfd12
Jul 27, 2016 09:26 AM
kent00SS
Jul 16, 2007 03:56 PM
