Flasher going nuts
Old Jul 26, 2016 | 06:06 AM
Mcvfd12's Avatar
Default Flasher going nuts
Hi guys, I have an intermittent issue with my turn signals. Some times the car will flash the turn signals what seems like 1000 times a minute and other times it works fine. Not sure what to change, isn't there a hazard/flasher relay or module or something behind the dash? Or do I have a different issue?
Old Jul 26, 2016 | 10:30 AM
ohara's Avatar
Problem: my turn signals don’t work
Cause: Bad hazard switch
Temporary Solution: bang on the dashboard near the hazard switch to see if the turn signals work again.
Permanent Solution: Replace the hazard switch
Prevention: nothing
Here is a link to a write up in the forum with a list of common problems, it is good to give it a read through as it helps with most common issues that other members have dealt with and resolved
https://montecarloforum.com/forum/fw...lutions-30154/
Old Jul 27, 2016 | 07:41 AM
Mcvfd12's Avatar
Thanks for the reply, the turn signals are working, just rapidly blinking intermittently. Should I still go ahead and change the hazard switch?
Old Jul 27, 2016 | 09:26 AM
If they rapidly blink that means a bulb is out, if it's intermittent, I would check the relays for the flashers and the wiring.
