6th Gen ('00-'05): Fixing light behind speedometer on 2003 ss??
Old Aug 27, 2012 | 12:29 PM
01navyss's Avatar
Default Fixing light behind speedometer on 2003 ss??
How can i fix the light behind the speedo on a 2003 monte carlo ss? Any pictures of the back of the cluster? Thanks
Old Aug 27, 2012 | 10:35 PM
This is a really common topic if you search around you'll find lots of information on it and how to fix it.
Basically it's a small light that's soldered in the board behind the overlay. In order to fix it you must desolder the current bulb and solder in another with a resistor and it will fix your problem, but if you do LEDs you should do them all at once and if you're good enough at soldering you should do the stepper motors while you're at it because those will likely go next.
https://montecarloforum.com/forum/si...lem-fix-12319/
Old Aug 27, 2012 | 10:51 PM
16With01MonteSS's Avatar
Hey bro what Exaust do u have on ur car, mostly what mufflers?
Old Aug 27, 2012 | 11:35 PM
01navyss's Avatar
What is the cheapest I can fix or have it fixed for?
mrl390
FWD Tech Guides '95-'07
39
Aug 15, 2013 09:37 AM
S818
Oct 5, 2010 03:34 AM
Jack The Ripper
Mar 21, 2010 10:04 PM
BeachBumMike
Feb 4, 2007 01:28 PM
79Monte
Jan 27, 2007 05:42 PM
