Factory Tach
Old Oct 31, 2006 | 07:26 PM
steptoe's Avatar
Default Factory Tach
I am switching my '86 Monte instrument cluster over to factory gauges. I have found good wiring diagrams which I posted http://msnusers.com/1986montecarloinformation for the car but have a problem. There is a factory tach in the cluster to be installed. The wiring diagrams call for a FILTER located somewhere between the ignition coil and the tach. What is this filter and where can it be found? Does anyone know? Thanks, David
Old Nov 6, 2006 | 06:10 PM
01pacecar's Avatar
Default RE: Factory Tach
The filters I've seen look like a condenser out of the old points type ignition systems. They block ignintion interference to the tach. Try it without a filter and see how it works.
Old Nov 6, 2006 | 07:56 PM
steptoe's Avatar
Thanks, 01. I went to a junk yard Saturday and found the filter. Yeah, it looks like a condenser. I got the whole setup from the distributor to the dashboard connector for $1.00. Also got a vacuum switch to control the lock-up converter for another $1.00. How's that for a GOOD day? Ha, ha.
Old Nov 6, 2006 | 10:05 PM
DESS03's Avatar
sounds like you got lucky hope you find more garage sale deals
Old Nov 7, 2006 | 12:33 AM
RippedMantis's Avatar
I had an '86 LS and I took apart the dash to put in an aftermarket tach as my LS did not come with one. I think you need to use the filter. I didn't and my tach quit working, not to mention a jumpy needle. Course I could have hooked it up wrong in the first place.
sorcier11
Dec 31, 2008 11:14 AM
24_48Fan
Apr 19, 2008 07:48 PM
Krysden
Jan 11, 2008 04:49 PM
GreyMonte
Oct 10, 2006 06:08 PM
Boost
Apr 30, 2005 10:15 PM
