Driver side AC not blowing cold air!
Old May 25, 2012 | 12:33 AM
S.O.G.'s Avatar
Thumbs down Driver side AC not blowing cold air!
I have a 04 monte ss s/c and my ac on the driver side does not blow cold air! Doesnt make sense tho cuz the passanger side works just fine???
Old May 25, 2012 | 01:41 AM
Enzo354's Avatar
STILL SLOW
Mine did the same thing all last summer and now it just blows hot air all around. Have you tried getting it checked for leaks and recharged?
Old May 25, 2012 | 04:51 AM
Check out below link (Hope it helps) Good Luck
https://montecarloforum.com/forum/ge...ne-side-21563/
and
Blend Door Actuator?
https://www.partshighway.com/search....nologyid=10721
Old May 25, 2012 | 06:14 AM
Sounds like the AC works 100% on the passenger side? Could be a bad blend door actuator. I recently had my HVAC module all apart (to change out the evaporator core), during re-assembly I noticed my driver side blend door seemed tighter then the passenger side (like it had some resistance). I can't say it never worked, but I don't think it worked as well as it should have since I've owned it (I think when the actuator meets up with so much resistance, it stops). I found a couple spots that the door rubbed the housing. I used some sand paper and by hand sanded down those spots, now it moves as easy at the other door. When I re-assembled everything, I put the TINIEST amount of lubricant on the pivot points.
Unfortunately, the only way to do what I did is remove the HVAC module.
But if it's JUST the actuator, I think that can be reached from under the dash.
Old May 25, 2012 | 11:38 AM
S.O.G.'s Avatar
Thanks for the info im gonna check it out! N i did recharge it wit the AC that has the leak seal or whatever but still isnt as cold as passanger side. Ill definitely check out the actuator!
Old May 25, 2012 | 07:32 PM
aussiek2000's Avatar
Blend door actuator. Pretty common on these things.
Here is a tutorial
http://www.sparkys-answers.com/2009/...ivers.html?m=1
Old May 25, 2012 | 09:06 PM
The car only has one evaporator core (even though it has duel climate control), so if one side is cold and the other is not, I don't think you have to worry about the Freon charge.
Old May 25, 2012 | 09:08 PM
I wouldn't be so sure about that Jason. When my freon was low my driver side wasn't as cold. But it was low because my condensor was cracked...
Blakejake33
Aug 27, 2015 07:01 AM
Jurbean
Oct 25, 2013 10:18 AM
mattilus2121
Jun 23, 2010 11:36 AM
hatecc
Nov 13, 2007 06:26 PM
MYSSMONTE
Nov 5, 2007 09:56 AM
