Double whammy!!
not all came with amps. best way to tell if you had one is if its in the trunk between the two rear speakers. you should see it. another way to check is look at the option codes on your trunk lid. its a label full of 3 number/letter codes. There were three main packages 1SA, 1SB, and 1SC. If you have 1SA then chances are you do not have a amp.
Alan
Alan
goat_230
16
04-17-2008 09:32 AM
