Double whammy!!
FIRST DO ALL MC'S COME WITH AMPS?:confused:
SECOND HOW DO I CONNECT THE RADIO SO I CAN GET SOUND?:confused: |
not all came with amps. best way to tell if you had one is if its in the trunk between the two rear speakers. you should see it. another way to check is look at the option codes on your trunk lid. its a label full of 3 number/letter codes. There were three main packages 1SA, 1SB, and 1SC. If you have 1SA then chances are you do not have a amp.
Alan |
Yup it all depends on your pkg you got & like stated above its between the rear speakers
does your stereo turn on? Any speakers produce sounds ? More details please
