6th Gen ('00-'05): Connector on Auto-Dim Mirror
Old May 29, 2015 | 01:02 PM
2004SSIntimidator's Avatar
Default Connector on Auto-Dim Mirror
The clip on the connector is broken and it won't seat correctly. When I wiggle it just right the auto dim and lights do work.
Anybody know where I can get another connector?
Old Jun 1, 2015 | 08:41 PM
Jason B's Avatar
I did some looking around. Thought i might find it on carid.com for the part # but no luck. You can call up a local chevy dealer and they may have some extras or be able to order some. Sorry.
Old Jun 1, 2015 | 09:07 PM
ohara's Avatar
RockAuto Parts Catalog may have the part as well
Old Jun 5, 2015 | 08:27 PM
seen03's Avatar
~ Hopefully my reply isn't too late~
I was just browsing the forum and found this thread...you can indeed buy the rear view mirror plug from, "Rock Auto". Here's a link to the connector... https://www.rockauto.com/m/mobilecatalog.php?ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=3vpv2utkki6lq0trtel4b5j0o7
I personally ordered the, STANDARD MOTOR PRODUCTS plug, and the quality etc is fine..no issues. (As far as I can recall, Rock Auto didn't sell the "ACDelco" brand plug back when I bought mine.)
If you have the means/ability to solder, you might consider making all the connections that way. Only issue with soldering is, the OE/vehicle-side wires have corrosion resistance coating on the actual wire itself which prevents solder from "sticking" to the car's wire. (You can rough-up/sand the wires, and/or use, "soldering flux" >Radio Shack sells the flux to allow the solder to "stick" to the car's wire).
...ooor use the butt-connectors. The best tip I can give for using them for all those wires is, "stagger"the wire lengths coming from the plug so that all those butt-connectors are not all grouped into one area =a big fat chunk of connectors you'll need to try n shove up into the headliner.
Oh, another tip...swap the wires over to the new plug 'one-at-a-time' as to not get them mixed up.
*Forgive me if you didn't need any of the install "insight"..lol
Hope this helps..
Red Nightmare
Dec 6, 2012 04:49 PM
RosDaddy
Mar 14, 2010 01:47 PM
Daytona02ca
Dec 1, 2008 03:47 PM
nitehwk10
Sep 9, 2008 12:41 PM
Epic
Aug 26, 2007 10:06 AM
