Climate control light bulb size?
Hi all,
Does anyone know what the light bulb size is for the light that lights up the climate control display?
Mine have been burned out for a while now and its starting to get on my nerves ha ha.
Thanks!
Thanks!
I do not believe they are replaceable... They are hard wired... You would need to solder them in, in which case you might as well switch them to LEDs...
Crusader is right. They are hard wired into the board. My '02 Grand Am had bulbs that were out and I followed a "cheater" idea someone on a forum posted... Just mounted a single LED strip into the unit. On the Grand Am, worked PERFECTLY! I've never taken apart the Monte one.... Not sure if the same idea would work as well or not.
7th Gen ('06-'07): In dash light bulb size?
MyMonte06
Jan 11, 2013 05:29 PM
