Clicking sound from radio/dash
Old Jun 8, 2015 | 04:51 PM
tweek's Avatar
Default Clicking sound from radio/dash
Ok guys here is the issue. I have been getting a clicking sound from my dash for over a month now. I think its coming from the radio it happens when I unarm the car as well as open the door and also at random times. It happened when I was sitting in the car so I took out the cd from the headunit and it stopped. But it still happens every day. Its quite loud and annoying. The Headunit I have is Pioneer App Radio 2. Anyone else have this issue?
Old Jun 11, 2015 | 08:33 AM
sounds like there something wrong with the CD Player...
Does it only do it when the motor is running?started?
Maybe its actually the blend door actuator for your heat and ac?
Its also up in the dash around the radio area..
Old Jun 11, 2015 | 07:17 PM
To see if it is the radio take out the fuse for the radio so it won't turn on. Then you can see if the noise is still there.
Old Jun 12, 2015 | 08:06 AM
tweek's Avatar
No it does it when the car is off too
Old Feb 27, 2023 | 03:50 PM
Tfarrow16's Avatar
have you figured this out??? Mine is doing this to and causing car to die
feltes94
Dec 3, 2016 01:42 PM
anagy007
13
Apr 16, 2011 12:06 PM
motoguy1012
Jun 24, 2007 07:41 PM
Sciggy
Sep 18, 2006 09:13 PM
