Changing LED color in Control buttons
Just discovered a great trick.
The LED bulbs in the window and lock controls have a blue/green rubber sleeve.
I wanted red ...I pulled the sleeve off and used a red sharpie to color the bulb WORKED Great! Pics to come after I get the whole inside done... Just wanted to share my find.
(I could not find red sleeves anywhere for those little bulbs)
Something like this:
Red Fog Light Headlight
If those are true LEDs in those switches, a sharpie should hold up (LEDs don't generate enough heat).
I thought the buttons/switches were still incandescent bulbs (but I'm betting low to no heat).
They are real tiny I tried some translucent red tape (the type you do a temp break light repair with) it blocked out too much of the light.
If it is true that they start to look bad after a while i'll have to think of something else. The lights are soldered in I really don't feel like taking them out and soldering in real red LEDs. You guys know how picky I am with the Deuce - If any thing don't look right I do it over again .
MJClemm
FWD Tech Guides '95-'07
78
Sep 24, 2014 09:26 AM
KingOf206
Dec 25, 2013 07:12 AM
Bobbo51508
Jul 13, 2010 01:14 PM
cain45
Dec 14, 2006 09:53 AM
