cd changer wiring
Old Aug 22, 2013 | 08:39 AM
ssdriver's Avatar
Default cd changer wiring
I'm thinking about installing a CD changer in my 05, it will be frequency modulated. My problem is locating wiring taps to hook up the always hot wire and the ignition on wire. ground is no problem. Can anybody advise me on this.
Thanks
Unit considering is a Pioneer CDX-FM657
Problem solved, thanks for the help.
Old Aug 22, 2013 | 09:41 AM
ssdriver's Avatar
Thanks
It might be helpful if someone could post a picture of the 6th. gen. (05 monte) radio wiring harness schematic.
Thanks
Old Aug 22, 2013 | 10:35 AM
Hi Bob,
Check out the below links to see `if they help you + plus check back to see what our expert radio Member's post when they view your thread..Good Luck
Old Aug 23, 2013 | 07:41 AM
03SSLE's Avatar
Metra makes a variety of adapter harnesses that allow you to plug aftermarket stereos directly into the factory wiring. That would be the easiest way to do it.
Car Selector < Link
Old Aug 24, 2013 | 04:26 PM
ssdriver's Avatar
Using the rear acc. power wiring for always hot 12 v. and ground, using the switched power on the unused seat heater switch connecter. Both in the same area behind seat heater switch cover in console above cup holder.
Hope this helps someone in need of the same type wire circuits.
Endo
Nov 11, 2007 03:09 PM
Endo
Nov 9, 2007 10:43 AM
rlm22b
Jan 17, 2007 01:48 PM
zipsayain
Jul 18, 2006 12:15 PM
ralphtrent
Aug 18, 2005 07:07 PM
