Battery question
Old Mar 26, 2014 | 09:41 PM
Griffindor's Avatar
Default Battery question
When connecting the negative clip to the dead car do you have to connect it to a metal part on the engine or could you connect it to any metal part under the hood? For example the two metal strut braces or whatever they are that are on both sides of the engine.
Old Mar 26, 2014 | 11:54 PM
TomF106SS's Avatar
I connect to the bolt holding the alternator.
anything Chassis should be 'ground'. Chassis is connected to the neg on the battery. Closer to the main connection is better.
Old Mar 27, 2014 | 07:34 AM
For a car battery, you will have two grounds, one to the chassis of the car, and the other to the engine. So you will have an engine and chassis ground.
Old Mar 27, 2014 | 08:02 AM
2000_BLACK_SS's Avatar
So are you asking about jumping a car? then yes you want to connect to some where on the frame to complete the circuit when jumping a car.
cnogood
Sep 20, 2014 04:16 PM
monte carlo 3831
Dec 1, 2013 09:58 PM
70monte1
Jun 14, 2012 05:12 AM
Bonanno9
Dec 21, 2010 01:48 PM
DCfla
Aug 20, 2009 01:26 AM
