battery help with my stereo
Old Aug 14, 2007 | 10:47 AM
mj_duffy1989's Avatar
Default battery help with my stereo
hi guys im new to this site, and i have a 1998 monte carlo LS yeah i know a little old school, but im in the process of putting in a custom stereo (rear speakers, door speakers, amp, and subs, and head unit). So far everything is going fine head unit and door speakers and rears are run and work with no problem but i need to run a power wire up to my battery and it is tucked all the way up near my front tire near the bottom of the car, and i was looking for some advice as to what i need to do to get to it and if i should look into buying a better battery possibly.
mj_duffy1989
Old Aug 14, 2007 | 11:33 AM
I think ? Maybe ?
I would wait for a member that knows something : )
but until then, you can check out the below infor/site.
Just Maybe ? It will help : )
Oh, Welcome to the MCF : )
Be Patience, there are many good member's with Radio Hook-Up Knowledge.
Replacing battery
You have to remove the black plastic rivets on the winshield washer fluid container that sits above the battery and remove it. you will then see that battery and be able to replace it.
Rockford Fosgate CP10PO 10 AWG Power Installation Kit
10 AWG Power installation kit. Kit includes 17ft. 10 AWG red power cable, 3ft. 10 AWG black ground cable, ATC fuse holder with 25 amp fuse, three 4 AWG solid copper seamless ring terminals and accessory pack.
List Price$49.99
Your Price$39.99
Oh, Good Luck on your install : )
`Space
Last edited by Taz; Jun 17, 2010 at 07:02 PM. Reason: Repaired coding issues from old forum
Old Aug 14, 2007 | 11:43 AM
wiz kidd's Avatar
Default RE: battery removal?
i would look into running a yellow top optima battery if your running a stereo, they're the best battery that i know of and they can be mounted anywhere in any direction
r00t
Apr 25, 2015 10:48 AM
cnogood
Sep 20, 2014 04:16 PM
70monte1
Jun 14, 2012 05:12 AM
DCfla
Aug 20, 2009 01:26 AM
xjcurtisx
Nov 17, 2008 10:47 PM
