Amp Adaptor
Old Aug 25, 2007 | 08:53 AM
MIKE07083's Avatar
Default Amp Adaptor
HI Everyone...Another question on upgrading my M/C stereo...Im looking at just add a 4 channel amp to power my infinity kappa's and keep the factory head unit. Dose anyone know the correct adaptor i need? Looking online ive come up with 2,both by PAC...The C2A-GM24 and the AOEM-GM24. I that the upgraded system with the factory amp in the trunk,not the bose system...Also,is there an adaptor that i can plug into the factory speaker harness from the new amp? I would rather not go cutting wires. Thank you for all your help so far.....Mike
Old Aug 25, 2007 | 10:24 PM
04MonteLS's Avatar
Default RE: Amp Adaptor
If you're keeping the factory head unit you won't need the GM24 harness, that's only needed if you're replacing the factory head unit. All you're gonna need is a high to low converter and you're gonna have to do the amp bypass as well.
Old Aug 26, 2007 | 07:50 PM
mickey's Avatar
when i ran my amp i never did the bypass.
it sounded good,
BUT from wha ti have heaerd is the by pass makes the sound better.
But agian i did mine with out it so if you dont want to you do not have to do it.
But i would say it is to your advantage to do so
blackmonte781
Feb 22, 2011 07:29 PM
paintballerr78
Sep 6, 2009 06:36 PM
MIKE07083
Aug 14, 2007 07:41 PM
victoryred05
Jan 10, 2007 02:45 PM
