2006 SS rear speaker harness problems
Old Jun 30, 2015 | 01:04 AM
spacejam111's Avatar
Default 2006 SS rear speaker harness problems
i have an 06 ss, factory system. i purchased speakers to install in the rear, but when trying to connect, i notice the harness and factory wires do not work well together. the male end on the harness has two pins. the female end of the factory wiring has four openings in a "four square" formation. this vehicle does have a factory amp installed in the trunk on the under body of the deck. any clue as to whats going on or if i need any additional parts would help. thanks
Old Jun 30, 2015 | 06:35 PM
JayBay's Avatar
did the speakers come with wiring, so you can rewire the factory wire so the plugs fit perfect to the speakers?
Old Jun 30, 2015 | 06:48 PM
Nope, no wiring for the speakers. I did find out this morning that the harness didn't fit because there is another specifically for factory amps. Part doesn't come up in searches, but it does exist and is hard to find with no part no. Ended up cutting wires for the install. Thanks for the help man.
cole4201
Jan 15, 2014 05:54 PM
Chucks88SS
Mar 22, 2008 10:45 AM
ricrush
Sep 6, 2007 11:18 AM
04MonteLS
Jun 18, 2007 06:01 AM
