2006 Monte power input to radio lights
Old Mar 23, 2012 | 11:31 AM
Default 2006 Monte power input to radio lights
I am adding a mod in the Deuce and need to tap into a power lead in the dash that is controlled by the dash light dimmer switch
I would like to tap into the power lead that supplies power to the stock radio lights. Rather than mess trial and error with the wires does any one know which wires supply power to the radio lights? Or if you know of any other like power source (that is dimable by the dash light switch) near this area that would help too.
As always thanks!
Old Mar 23, 2012 | 04:31 PM
Barovelli's Avatar
Metra says it's the orange wire in the 14 pin connector. I'd check there first.
http://www.metraonline.com/files/pro...NST71-2105.pdf
rg9johns
Jan 2, 2022 05:51 PM
Habbibie
Aug 1, 2015 02:24 PM
rg9johns
Aug 22, 2014 10:46 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
Krysden
Oct 30, 2007 12:51 PM
