2006 Monte Carlo
So my front speakers on my car blew out, major let down, I've been looking to replace both front and rear speakers since this has happened. I think I found what I'm going with
Boston Acoustic SC60 (Front) and SC65 (Rear)
Now I jus need to find an AMP to go with them, I dont know how to tell if things are over powered or under powered. I do plan on getting 2 12 eventually so I need everything to be compatible... Any opinions.?
meh Boston accoustic aint what it once was.
I really like these speakes.
Pioneer TS-D1720C (tsd1720c) 6-3/4" (Oversized 6-1/2") 2-way D-
Pioneer TS-D1602R 6-1/2" 2-way D-Series Car Speakers
you would of course need a 6x9 adapter bracket but they don't cost much,
partsexpress.com will have them for like 15$
amp it with this and keep it simple
Polk Audio PA1100.5 Class D 5-Channel Amplifier
than you can keep the pioneer theme and run it on
JBL P1224 12" Dual 4 ohm Power Series Subwoofer
those power series sub's are the same things as their GTI which are their best subs (sub i run) and they are great, they just can't take as much power as the GTI and don't do as well in IB setup, but you'll be puting them in a box so that doesn't matter. you should only need one of those, i'd do ported i think you would be happy with that.
just spit balling some ideas, this is a setup i put together a bit ago for a buddy, we went with a couple dif things because of his budget but for that, and a deck you'll be under 1000$ depending on what you do, and who installs it. you could go with those speakers and a simple
RE Audio DTS-500.4 400W DTS Series 4-Channel Class AB Amplifier
that works as well, bit cheaper but than you'll need a sub amp, so your looking on saving 100$ in that rout. don't be discourtaged if your budgets much lower, you can do all kinds of things, just stay away from the super cheap stuff.
I got 2 older MTX Thunder amps, the solid underrated ones for sale. I dont want much at all just need them gone.
The MTX 4244 4 channel and 4250D Sub(mono) class D. Black with the chrome in perfect working conditions. No dents or deep scratches just chrome has scratches on them, nothing bad tho.
Lmk, here's pics from another site I'm on, I am 350zkid.
Hit me up on a PM if you're interested or need additional pics.
and YES i know the date is wrong, didnt notice I pressed the 6 instead of 4 on todays date until I uploaded them via photobucket. Their packaged and ready to go
7th Gen ('06-'07): 16" Monte Carlo Rims OK to use with 2006 Monte Carlo SS?
kkritislas
Nov 11, 2014 08:14 PM
Dovas Monte
Feb 1, 2011 01:24 PM
you should jump on that!
