2004 SS Driver's Air Bag Removal
Old Feb 9, 2012 | 10:29 AM
Larrysmonte's Avatar
Default 2004 SS Driver's Air Bag Removal
Is there a specialty tool that makes it easy to remove the airbag on a 2004 MCSS? We have the leather wheel with extra radio and cruise buttons. On the back of the steering wheel there is a plastic protection cover that makes it very difficult to get to the spring loads holding the three pins for the air bag. It looks like you need to slide a tool up in behind the cover and turn to release the bag.
Any help is greatly appreciated.
Larry
Old Feb 9, 2012 | 11:02 AM
You can't get a flat-head to the clips on the back and turn them counterclockwise?
Old Feb 9, 2012 | 12:00 PM
You need at least two flat head screw drivers (three really help). The plastic cover being on or off does not make a difference. Put the screw drivers in the small slots on the back, about a 90 degree turn and that should release the retaining clip and pull the bag forward (might take a little wiggling).
So let me get this straight - The three holes in the back of the cover have three torx screws in them that hold the back cover onto the steering wheel. I removed the torx screws. Do I go in that same place with a flat head screwdriver to release the air bag? Did I need to get the torx screws out of there to release the air bag?
I will probably end up feeling pretty stupid on how much I have struggled with this in the end :-)
Old Feb 9, 2012 | 12:42 PM
I haven't done this, but I BELIEVE those 3 torx screws are to remove the face, and there should be 4 other holes on the back of the steering wheel that a flat-head can fit into and release the air-bag clips.
Old Feb 9, 2012 | 01:02 PM
Franks 03SS's Avatar
2011 Monte Of The Year
There should be 3 other holes on the back of the steering wheel that a flat-head can fit into and release the air-bag clips.
what he said
Old Feb 9, 2012 | 01:12 PM
Really, only 3 on ours? I thought it was a square to pop? Like I said, haven't actually done it on my monte.
Old Feb 9, 2012 | 01:21 PM
yep take a look
>>> https://montecarloforum.com/forum/ge...al-help-28212/ <<<
Old Feb 9, 2012 | 01:27 PM
Ahhh good to know.
Old Feb 9, 2012 | 01:47 PM
Thanks guys. You're the greatest.
Larry
