2001 Monte - blown stock Amp
Old Jan 30, 2009 | 08:57 AM
sleighbor's Avatar
Default 2001 Monte - blown stock Amp
Hey guys,
2001 Monte Carlo LS, all stock. It seems like the amp is shot. The stereo cuts out. Bang on the amp a few times and it will come back on. I'm trying to help out a friend here and all I would like to do is swap it out with the same unit. Can anyone tell me where I can get one, maybe a part #?
Thanks,
Kevin
Old Jan 30, 2009 | 11:57 AM
Default RE: 2001 Monte - blown stock Amp
Have you checked all the wires going to the AMP? there could be a connection problem.
try gmpartsdirect.com under instrument panel.
Old Jan 30, 2009 | 12:00 PM
sleighbor's Avatar
could be a bad wiring connection. I'll take a look at that and the gmpartsdirect site.
Thank you,
Kevin
Old Feb 1, 2009 | 10:52 AM
vita's Avatar
its either a short in the wire (pinch, or a connection issue causes the amp to drop into protection if it has it) or the amp itself is shot. Amps though, usually work or dont.... they dont work for a minute then just die.
rgant_19
Apr 29, 2011 02:21 PM
MonteNoob
17
Aug 3, 2010 10:28 AM
paintballerr78
Dec 10, 2009 09:40 PM
04superjr
Mar 15, 2009 01:50 PM
RocknSS04
May 25, 2008 06:36 AM
