05 Monte Carlo Amp Power/Ground Wires
Old Apr 19, 2012 | 07:33 PM
bulletpr00fxx's Avatar
Default 05 Monte Carlo Amp Power/Ground Wires
I have been looking for a way to run the power wire to my amp and just cant seem to find a good location like a rubber boot or anything to run it through. And the fender idea doesn't look good because the hood hinges are pretty tight and I have 4 gauge wire, and I don't want to pinch/cut it... Any Ideas?
Also, I haven't looked into the trunk much yet, but is there a good place to put the ground?
Thanks.
Old Apr 20, 2012 | 06:50 PM
Warhorse's Avatar
There is an article in the how-to section on this. I ran mine that way, through the passenger side floor, through the grommet, along sill into trunk, Grounded it on rear seat belt bolt.
Mike
Old Apr 20, 2012 | 07:36 PM
walkingonabullet's Avatar
you can run it down the channel on the left hand side, up and aruond the door down the frame of the door outlet, and along the bottom corner panel to under the rear seat. you can also run it through a grommit on the passenger side floot, if you remove your rad fluid container you can see the grommit behind it than run it down the corner panel or the center console. i ran mine down the center console my self. but thats just me
Old Apr 22, 2012 | 12:10 AM
I may try that... We will see.
And I'll go look in the how to section later as well. Im wanting to get this done soon. I just need to get a new fuse holder first. hopefully it will be done within the next two weeks as long as I don't get worked to death at my job...
Chris s
Jan 26, 2013 04:49 PM
mwjames
Apr 29, 2012 10:36 PM
Cowboy6622
Feb 6, 2012 10:56 AM
buzdof
Dec 22, 2005 02:43 PM
blownss
Jul 25, 2005 07:41 PM
