05 Monte Carlo Amp Power/Ground Wires
I have been looking for a way to run the power wire to my amp and just cant seem to find a good location like a rubber boot or anything to run it through. And the fender idea doesn't look good because the hood hinges are pretty tight and I have 4 gauge wire, and I don't want to pinch/cut it... Any Ideas?
Also, I haven't looked into the trunk much yet, but is there a good place to put the ground?
Thanks.
Thanks.
you can run it down the channel on the left hand side, up and aruond the door down the frame of the door outlet, and along the bottom corner panel to under the rear seat. you can also run it through a grommit on the passenger side floot, if you remove your rad fluid container you can see the grommit behind it than run it down the corner panel or the center console. i ran mine down the center console my self. but thats just me
And I'll go look in the how to section later as well. Im wanting to get this done soon. I just need to get a new fuse holder first. hopefully it will be done within the next two weeks as long as I don't get worked to death at my job...
Chris s
Jan 26, 2013 04:49 PM
Cowboy6622
Feb 6, 2012 10:56 AM
