00-05 how to install subs and an amp to your factory head unit
Old Feb 29, 2012 | 09:21 PM
  #51
Originally Posted by MONTE2000SS
wanted to see if it worked lol
looks good!
Old Mar 1, 2012 | 07:09 PM
  #52
MONTE2000SS's Avatar
SUCCESS !!!!!!!!!! i hooked up my system today amd wow it hits hella hard!!!!!i took a piece of hard copper and cut a point on it and went right down through the passenger side gromet with the power wire taped to it right with the other wire......hookedup ground on rear strut tower amd ran memory wire to the cig/aux fuse and shoved the fuse back in with the wire and connected the line convertor both negetives and positive together to one speaker and then connected my rca wires put the fuse in and hooked battery back up.....awesome write THANKS A TON TO THE POST!!!!!!!i do have a question about the line convertor though how high am i supposed to turn them up right now i have them all the way up didnt play with it to long so still have to do a little adjustment but i have the fierce filc20v2 line convertors so i heard they are the same as pac sni35.......god i love BASSSSSSS!!!!!!! cant wait to drive it more to hear it cause its definetly louder than my truck
Old Mar 1, 2012 | 07:17 PM
  #53
is there no gain **** inside the casing?
Old Mar 1, 2012 | 07:24 PM
  #54
yes those two ***** are turned all the way up on line convertors just wondering how high should they be cause i noticed that when i turn the radio all the way down still here alittle bass still...
Old Mar 1, 2012 | 07:26 PM
  #55
hey also sent youmy address.....check your mail
Old Mar 1, 2012 | 07:29 PM
  #56
you should turn them down so there is no distortion when playing at your normal listening level.
replied to your pm also
Old Mar 1, 2012 | 10:03 PM
  #57
hey where did you get you grill?????????????
Old Mar 1, 2012 | 10:53 PM
  #58
Here:
SLP Chevy Monte Carlo Grille 2000-2005 Sport Grill SS | eBay
Old Mar 2, 2012 | 04:59 PM
  #59
are these loc s supposed to be ground or what for some reason today the stereo just started to go baaaaaaaaaaaaaaaaaaaa through sub turn the radio off and and back to normal i did do what trewyn15 said to do and turn them down but i am still wondering why it did what it did and are these two brown wires the grounds for the twochannel locs i got ?????????????????????after i turn it off and back on back to normal and also i am getting a little motor sounds through my sub ......
Old Mar 2, 2012 | 05:31 PM
  #60
are the two brown wires blocked off at all? if you have them hanging free they may have touched eachother, also are the RCA's by any power wires?
