Z34 Exhaust on an LS
Old Mar 26, 2012 | 07:29 PM
anthony_8606's Avatar
Default Z34 Exhaust on an LS
I picked up an exhaust off of a 1996 Z34 from the junk yard for 45 bucks. I have a 1998 LS with the 3.1L engine. Would this be a direct fit onto my Monte? If so, would this cause any problems from putting this 3.4L exhaust on my 3.1L?
Old Mar 26, 2012 | 07:36 PM
bizparr's Avatar
If it's just the catback I'd assume it'll bolt right up.
Nice find.
Old Mar 26, 2012 | 09:02 PM
mrl390's Avatar
As long as the flange on the catback is the same as the flange on your downpipe, everything else will fit. Did you grab the hangers from the drivers side muffler off the Z34?
Old Mar 26, 2012 | 09:09 PM
It should fit no problem, may just need a hanger or two
Old Mar 27, 2012 | 07:57 AM
Oops. I forgot to get the hangers. I will have to make a trip up to Auto Zone to get the hangers. Thanks for the info guys!
Old Mar 27, 2012 | 08:19 AM
Originally Posted by anthony_8606
Oops. I forgot to get the hangers.I will have to make a trip up to Auto Zone to get the hangers. Thanks for the info guys!
If you're getting it welded on, the welder shouldn't have an issue with adding some hangers
Old Mar 28, 2012 | 06:42 PM
mrl390's Avatar
There shouldnt be any welding required. The hanger for the driver side muffler should unbolt from the car. Get the hanger and the two rubbers and everything else should be a direct fit. I ask about the flange on the DP because different year Z34s use different flanges on the DP from what I have read. I would check to be 100% sure it fits.
Old Mar 28, 2012 | 08:14 PM
zzapultimate's Avatar
Great find Best way to get dual exhaust!
Old Mar 29, 2012 | 10:24 PM
I got it put on with some universal exhaust hangers but the are pretty crappy so I will pick up the original Z34 exhaust hangers next time I get to the junk yard. The down pipe has a different flange which is a little off but it will work for now until I can get to a muffler shop to swap the connector. Here are a couple of picture of what it looks like so far. The driver side is hanging down a little farther than it should be because of the universal hanger that does not fit right. Not too bad for the price I paid for it...
Old Mar 29, 2012 | 10:26 PM
Please don't hold the ugliness of the paint work against me! Haha! It will be headed to the paint shop once I get the body flaws worked out.
smolek37k
Jan 5, 2008 12:49 AM
mrl390
Nov 4, 2007 05:28 AM
smolek37k
Nov 8, 2006 03:01 AM
zapp59
Aug 1, 2006 02:46 PM
cm770011
Oct 26, 2005 11:21 PM
