is wrapping the plog safe
Old Jul 17, 2013 | 04:30 PM
fullmetal jacket's Avatar
Default is wrapping the plog safe
since I got the zzp plog no ceramic it comes with no heat should does anyone recommend wrapping the plog to keep temps down since the heat shield from the old manifold doesn't fit
Old Jul 17, 2013 | 05:37 PM
I have a zzp plog no ceramic with no heat shield & I have no problem with it. I have a ceramic coated crossover pipe..
Here's a pic of my engine..
Here's an older pic of it..
Old Jul 17, 2013 | 06:02 PM
Nice engine bay just worried about temps under the hood we do everything to reduce wouldn't this just add unwanted heat with no barrier just wondering since zzp sells every little thing for reducing heat soak
Old Jul 17, 2013 | 07:22 PM
Is it stainless? If so don't wrap it.
Old Jul 17, 2013 | 08:37 PM
Stainless or not, I believe the recommendation is no wrapping. Zjerry, Chibi and I all have plogs, no wrap, no shield, no problems
Old Jul 17, 2013 | 08:43 PM
I don't think the heat off the plog makes a big difference over stock ..
It maybe the same if measured ??? It feels the same ..
Old Jul 17, 2013 | 09:20 PM
I would not wrap them, trapping the heat will only serve to make the metal more brittle and already the Plogs are prone to cracking. My friend has went through 2 sets of headers on his 5.0 mustang and it was deduced that the wrapping contributed to premature failure. Was trapping road salts and led to corrosion related failure. I have all mine ceramic coated, not a cheap process but then neither are the new Cartuning exhaust manifolds which replaced my failed Plogs
Old Jul 18, 2013 | 11:48 AM
turbo monte's Avatar
i as well have a plog and it is not wrapped, they say not to wrap them because it will cause failure....
l0gitech87
May 11, 2014 07:25 AM
pahulkster
Sep 12, 2011 01:22 PM
labnjab
Oct 11, 2010 05:17 PM
