What Exactly am I supposed to Gut
Old Apr 8, 2008 | 07:51 PM
Cowboy6622's Avatar
Default What Exactly am I supposed to Gut
So I took the airbox apart today... there is nothign to gut!! No fins to cut out, nothing to bore because then it would be a completly open box. What exactly am I supposed to do to gut this thing? It's a perfectly straigth shot of air to the filter, through the pipe thing to the throttle body. No signs that it has ever beeen modified either. Whats the deal? What do I gut?
Old Apr 8, 2008 | 07:57 PM
mickey's Avatar
Default RE: What Exactly am I supposed to Gut
basically all your doing it opeing it up so that it can breath better.
when i did mien at first i took a hole saw and cut two big holes in the front of it so that it would get more air flow. to the filter
Old Apr 8, 2008 | 08:10 PM
RocknSS04's Avatar
That's about all you can do is cut the front out of it. Maybe the side, too?
Old Apr 11, 2008 | 01:26 PM
z34phoenix's Avatar
but you need to be careful where you cut so you dont suck in hot engine air....
this is why this is a cheep mod and not the best idea.... do a FWI and you will have a true cold air source that will work.
Old Apr 11, 2008 | 02:35 PM
RickCoMatic's Avatar
After reading all these Threads about Cold Air Intake ... I went-out and took a very close look at mine. I think mine IS a Cold Air Intake. The opening to the Airbox is behind the Headlight bringing-in air from outside the engine compartment.
I don't have the money to do any costly Mods, but it seems like I could smooth-out any surfaces that might be restrictive in getting the Outside air into the engine without any trouble.
Jake Long
Mar 17, 2015 08:51 AM
Rotaman
Oct 1, 2010 11:46 PM
red03ssmonte
Feb 12, 2009 01:20 PM
kweef
Oct 31, 2007 04:26 PM
01whitess
Feb 16, 2006 03:14 AM
