Upgrades on the way.
Old Apr 14, 2009 | 09:40 PM
  #31
As for not feeling much with your mods- the only two mods that I really could tell a night/day difference with my gtp were the 3.4" pulley and the 1.9 modded stock rockers. Everything else was questionable, but necessary.
Basically, nobody can say what you do/don't need to run a particular size pulley. The only way to know is to install the pulley and scan for KR.
x2 Even two bone stock L67's brand new won't respond the same way to KR. There are a lot of minor differences and variances (as there is with any production engine)- so although people can give you basic guidelines, nothing can replace a scan of your own car.
Be wary of the vendors suggestions. While all of the W-body vendors are more or less fair and honest remember that they are vendors and are in this business to make money. That said they will not hesitate to sell you something you may not need.
x2 Intense has been caught up in a couple big lies, ZZP has changed thier story on various mods through the years (usually reflecting the products they carry), and so on. IMO to an extent you're better off getting information off the forums than by taking everything the vendors say as truth.
Old Apr 14, 2009 | 10:17 PM
  #32
nemesis's Avatar
2009 Monte Of The Year
somebody explain this to me, how come my cool down fan won't turn on after the car is shut off? when i first start modding and bought my first pcm from zzp their advertise said that's another feature that come with. i had an impalaa ss told me the same thing with the fan not coming on after the car is off on his. this only happen on the 04-05 L67 not sure on other models. read on another forum and they said something about the BCM have something to do with, anybody know any thing on this?
Old Apr 15, 2009 | 01:54 AM
  #33
biggriggs's Avatar
I've honestly wondered about the fans not turning after the car is shut off myself.
My PCM is supposed to be set to have the fans run for two minutes after key off so that the engine gets airflow. (I've heard that some people wire their intercooler pump relay to do this as well).
My fans don't do this anyways.
-Riggs.
Old Apr 15, 2009 | 09:26 AM
  #34
I believe that only happens when the car temp is like <200° or something
Not everytime you shut the car off.
Old Apr 15, 2009 | 04:07 PM
  #35
04 Intimidator's Avatar
Originally Posted by nugzo
I thought i'd "FEEL" more though.
You won't feel it either. The stock mufflers aren't a bottleneck until you hit 300 WHP.
Old Apr 15, 2009 | 04:18 PM
  #36
I agree. They sell a few products that are quite useless (throttle body spacer anyone?) and as I've been reading Greg Bannish's book, some that are just awful since they don't tell you what you need to do. I'm not going to jump on his bandwagon yet until I research what I've "learned" from the book and get other opinions, but his writing has been the most informative I've read.
Old Apr 16, 2009 | 09:30 AM
  #37
hey intimidator, how's that book you wanted to make coming along?
Old Apr 16, 2009 | 12:13 PM
  #38
biggriggs's Avatar
That is what the PCM is set to do stock. The fans will stay on at key-off if the PCM goes into a failsafe mode (if your t-stat goes bad), or if the ECT is above a certain temp.
My PCM is supposed to be set so that the fans turn on for 2 minutes every time at key-off no matter what the ECT is.
The fans are also set to come on at 180* instead of the stock setting (212* i believe).
You can set the fan turn-on points differently with a tuner.
I would imagine that silverbullit isn't running the factory tune either.
In any event, they don't turn on after key-off even with the PCM set to do so. I haven't looked into it at all as it hasn't been too important so far. I kind of assumed that maybe the guy that did the tune forgot to actually change that setting, but if other guys with '04-'05 L67's are seeing the same thing then it could be something else overriding the PCM setting.
-Riggs.
Old Apr 16, 2009 | 04:25 PM
  #39
15 solid pages into it with alot of organization for another 20 pages or so.
Old Apr 17, 2009 | 08:49 AM
  #40
I can't wait
