throttle body spacer
does a theottle body spacer help or is it a waste
RE: throttle body spacer
i never saw a 3800 but i know that on the 660 they are pretty useless!
IMO its a waste unless you need a place to tap for nitrous.
It will keep the throttle body cooler, but when you consider that the tb is a short (maybe 6" long) and straight shot- air doesn't sit in there very long. I doubt you could measure a difference in hp on the dyno because the actual change in cylinder inlet temperatures probably won't change much at all. I think there is other stuff you could spend the ~$50 on. |
it wont do much... unless the design helps make a smoother transition from the TB to the intake manifold. besides isolating heat from the engine to the TB it also increase the volume of the intake manifold chamber... this adds a slight high RPM increase and throtle responce.
but the gain is very small and like said not even able to be seen on a dyno. it wont hurt but the money is better spent on another mod. |
hey- look at that slow monte [8D]-digiphx
nice to see you over here too kinda wierd being on a monte forum where I'm not captain post whore :D |
