Throttle body/maf ? for turbo l36 engine
Old Sep 7, 2014 | 01:42 PM
dgm's Avatar
dgm
Default Throttle body/maf ? for turbo l36 engine
Hi All - I was curious has anyone tried putting the slot style ls7 maf in stock throttle body location or if it would work. i currently have an LT1 maf with my cartuning kit and i just think there is a better way, that thing gets hot!!! sitting right above downpipe,esp here in FL - lol.... any combo of intake/tb/maf suggestions or ideas? thanks<Dennis
Old Sep 7, 2014 | 05:20 PM
We installed my ABACO digital MAF meter in the driver side fender well directly behind the relocated air filter. The 4 way digital air meter allows you to really dial in the air flow readings.
Abaco Performance Mass Air Flow Meter 85mm - Anderson Ford Motorsport
Old Sep 7, 2014 | 07:48 PM
Is your downpipe wrapped or ceramic coated? That would help cut down on the heat.
As for the LSx slot style MAF- I run one (in a 4" Texas Speed aluminum housing), but not in a stock TB. They definitely wouldn't drop into a stock TB- the LSx slot style are narrow and long- the stock ones are short and stubby- just a little square / circle opening.
Old Sep 8, 2014 | 07:03 AM
turbo monte's Avatar
Stock maf with an adjustable afc and some tune tweaks. That's all you need honestly.
dgm
Sep 22, 2014 10:15 PM
dgm
Jan 11, 2014 07:41 PM
gothkid
Aug 29, 2012 08:10 AM
inssanity21
FWD Tech Guides '95-'07
26
Jan 11, 2012 06:03 PM
f16fixr
Sep 29, 2008 08:19 AM
