Throttle body/maf ? for turbo l36 engine
Hi All - I was curious has anyone tried putting the slot style ls7 maf in stock throttle body location or if it would work. i currently have an LT1 maf with my cartuning kit and i just think there is a better way, that thing gets hot!!! sitting right above downpipe,esp here in FL - lol.... any combo of intake/tb/maf suggestions or ideas? thanks<Dennis
We installed my ABACO digital MAF meter in the driver side fender well directly behind the relocated air filter. The 4 way digital air meter allows you to really dial in the air flow readings.
Abaco Performance Mass Air Flow Meter 85mm - Anderson Ford Motorsport |
Is your downpipe wrapped or ceramic coated? That would help cut down on the heat.
As for the LSx slot style MAF- I run one (in a 4" Texas Speed aluminum housing), but not in a stock TB. They definitely wouldn't drop into a stock TB- the LSx slot style are narrow and long- the stock ones are short and stubby- just a little square / circle opening. |
Stock maf with an adjustable afc and some tune tweaks. That's all you need honestly.
