6th Gen ('00-'05): Shorter Dogbones with PLOG?
Old Dec 7, 2014 | 06:32 PM
Supercharged04's Avatar
Default Shorter Dogbones with PLOG?
I have a quick question and was wondering if someone knew off hand. I currently have 1" shorter dog bones and poly on my car and it's about time to put a PLOG on. Does the PLOG have enough clearance between the fans and the PLOG itself? It's pretty close as it is with the stock front manifold and I know certain headers have issues with the clearance. Thanks!
Old Dec 7, 2014 | 09:21 PM
owens91's Avatar
im not sure if its the same with the supercharged versions but the stock manifold came out easy for mines and the plog fit in even easier seeing as though its lighter and whatnot
Old Dec 7, 2014 | 09:34 PM
nitehawkjcb's Avatar
It should still fit fine...
Old Dec 7, 2014 | 11:50 PM
turbo monte's Avatar
Shouldn't be an issue at all fitting a plog in there.
Old Dec 8, 2014 | 05:58 AM
gasman's Avatar
P log will fit, but headers and short dog bones won't fit.. And that's comming former zzp when I asked them the same question
Old Dec 9, 2014 | 02:30 AM
Okay thanks guys. I just didn't want to tear the manifold off to find I had a clearence issue.
Old Dec 9, 2014 | 10:40 AM
l67ss's Avatar
Is youre car dropped?
Old Dec 10, 2014 | 12:16 PM
Not yet but it will be an a couple months. I believe the supercharged trim cars sit lower than a normal ss though. I'm assuming your question was going to be why did you get shorter dog bones. I figured I'd do it now with the poly instead of later. Car drives like a dream!
04MonteLS
May 6, 2010 12:03 AM
wht02monte
23
Mar 20, 2010 12:12 PM
2003supersport
Mar 2, 2009 03:20 PM
