shifting weird after the k&n???
Old May 16, 2011 | 01:22 PM
NYGiantsfan's Avatar
Default shifting weird after the k&n???
whatsup
i installed the k&N system a while back and noticed the tube keep falling/sliding out from the throttle body side and when it does it shifts weird/hard and when i put it back in and tighten it again it usually shift normally a month ago i got my tranny rebuilt and now it does the same thing even tho filter tube is in properly...
did anyone have this issue with the filter tube coming out of the throttle body side or the shifting issue after the install
im thinking about taking the car back to the tranny place buti still think its an issue with the K&n?
any help will be greatly appreciated thanks
Old May 16, 2011 | 01:37 PM
nitehawkjcb's Avatar
Try cleaning your MAF sensor. The "tube" is a vacuum line IIRC, it needs to be in tact and not leaking
Otherwise, I hope you got a warranty
Old May 16, 2011 | 03:25 PM
My machanic friend told me to clean the o2 sensor in the intake tube (with Carb Cleaner spray). The K&N filters are oiled and if they are over oiled the oil coats the o2 sensor. If you have had trans problems in the past they could still be haunting you
I have a K&N on my 06 SS and have had no problems
I want to add that this o2 sensor is a hair thin wire. Take extreame caution when cleaning it!
Old May 16, 2011 | 04:34 PM
Budsjlm's Avatar
My machanic friend told me to clean the MAF sensor in the intake tube (with Mass Air Flow Cleaner cost about $7 at your local auto parts store). The K&N filters are oiled and if they are over oiled the oil coats the MAF sensor. If you have had trans problems in the past they could still be haunting you
I want to add that this MAF sensor is a hair thin wire. Take extreame caution when cleaning it!
Fixed..
Thats the MAF sensor your thinking of but you are on the right path
becuase it is a sensitive device that measures airflow to your engine to help map out air/fuel mixture i do not sugest using carb cleaner you do not want any cleaner that will leave any residue on it becuase that can change the measurements of what it is taking, i sugest getting MAF cleaner cost about $7 from your local parts store and works wonders i had to do this on my 00 intrigue
MAF=MASS AIR FLOW sensor it can either be the plate slate syle or bar style
Plate syle(not official name but it's wat i call it) i do belive 6th gens are this style
or
bar style
Old May 16, 2011 | 09:40 PM
Enzo354's Avatar
STILL SLOW
Check all of your wires going to the pcm. I bumped one when I was installing my CAI and it screwed some stuff up really good.
Old May 16, 2011 | 09:44 PM
this and like others said, check the MAF
Old May 17, 2011 | 07:11 AM
Originally Posted by Budsjlm
Fixed..
Ya what he said (LOL)
Old May 18, 2011 | 02:26 PM
hotrodmonte's Avatar
Definately start with cleaning the MAF. Also I have seen K&N filters cause vehicles to run like crap. Some cars are sensitive to air flow. When you install a K&N and more air flows it can affect other parameters from the PCM.
Old May 31, 2011 | 11:51 PM
thanks a lot for the help, i tried cleaning the MAF and unfortunately no luck, what i did notice is that the bottom of the intake filter was rubbing on the wires connected to the pcm which were mostly stripped off from the plastic and some wires are deff touching i think i might have to some way separate the wires and cover each one with electrical tape ...wupty frgn doo ... i just hope when i do it at will solve that damn problem its so annoying to have this small retarded issue that causes other things, now because of the hard shifting i hear a lil knock like maybe a mount or link is messed up...thats gona have to wait for a paycheck lol
RasCricket
Jan 16, 2014 03:19 PM
NYGiantsfan
Jul 24, 2013 08:11 AM
Jamie
16
Jul 18, 2011 07:42 PM
SharpieMarker
Jan 31, 2011 01:58 PM
85_Monte_SC
Mar 22, 2005 01:05 AM
