Removing catalytic converter
Old Jul 28, 2009 | 09:26 PM
Four Paws's Avatar
Default Removing catalytic converter
Hey guys, new here. Just put a deposit on a clean '06 SS for a daily driver - haven't even picked it up yet. I did a quick search, but didn't find my answer. Just curious if there is an exhaust for our cars that deletes the CAT? I don't have emissions testing in my area, so I want to ditch the CAT to get rid of the heat and restricition and help the engine breathe, not to mention likely sound better! Is there an oxygen sensor after the CAT that I will need to fool so the computer doesn't throw a code? I see several CAT-back systems offered, but I want a full exhaust, even if I have to have it bent locally.
Thanks for your responses!
Old Jul 28, 2009 | 09:29 PM
kweef's Avatar
hmm better hope a cop never looks under ur car. id jsut get an exhaust with a high flow cat. ur car will breathe just fine with that unless u get into heavy engine modding
Old Jul 28, 2009 | 10:09 PM
Budsjlm's Avatar
i dont see a cop crawling under the car to check if there is a cat.. and sorry to say with out an extensive tune after removin the cat you'll throw codes..i dont even know if a tune could eliminate it
Old Jul 28, 2009 | 10:54 PM
Toasty's Avatar
you may be able to remove the cat and add an o2 simulator, not sure if there is an aftermaket PCM for the newer cars or not. that being said, if your cat is functioning, its really not going to affect you until you get way deep into engine mods... if anything get a high flow cat and you will be fine. car will likely smell more (and not in a good way) without it also.
...even though you dont have emissions testing, you are still legally required to have a cat... the fine of not having one is pretty hefty, if i recall.
Old Jul 29, 2009 | 07:14 AM
drewskie043's Avatar
from what i've heard, even the stock cats flow pretty well. i would invest in an aftermarket downpipe (from hogan performance) with a magnaflow high flow cat, or at least a downpipe welded to the stock cat. that along with a good catback system would net you some pretty good gains. there is an o2 sensor after the cat anyways so if i was you i would keep some sort of cat in there.
Old Jul 29, 2009 | 10:31 AM
RickAKATed10's Avatar
Photobucket
You won't find an exhaust system that isn't a cat-back for our cars. The only one actually offered is the Magnaflow one. So if you want to get rid of the cat you have to have the done by an exhaust shop.
Old Aug 1, 2009 | 06:48 PM
Yes
You won't find one either- the wbody exhaust system is broken into 3 main, replaceable sections- the headers/manifolds/crossover pipe; the downpipe (including the cat section), and the catback. Are you having trouble finding a downpipe for the car? I don't know if one is made or not for the SS yet. You may have to get a catback, and just have a downpipe made locally if you can't find one.
I don't see why it would be any different than on the older Wbodys?
You used to be able to either buy an O2 simulator that just plugged into the harness in place of the O2 sensor, or turn off the code with a pcm tune. From what I understand; there aren't O2 simulators for the newer style- but I still don't see why you can't take HPTuners or some other tuning software and turn the code reporting off.
thewhitestcarlouknow
Mar 7, 2022 05:50 PM
Dec 21, 2007 08:13 PM
04monte_Carlo
Oct 5, 2007 03:43 PM
Sackaphone
Apr 29, 2007 03:24 PM
mtwallet
Feb 25, 2007 09:16 PM
