Hardware for ZZP Downpipe?
Old Jul 29, 2009 | 08:53 PM
Pure2sin's Avatar
Default Hardware for ZZP Downpipe?
Does anyone know what size bolts you use for the ZZP downpipe install? I first have to find someone to install it but I wanna get stainless bolts and hardware to use to install it with. Bolt sizes and anything else you can think of that I will need. I have the downpipe with cat and flanges on both sides and got the gaskets that came with it.
Old Jul 30, 2009 | 08:48 AM
re-use bolts
but i believe they are M8s
Old Jul 30, 2009 | 10:58 AM
Toasty's Avatar
Originally Posted by chibiblacksheep
re-use bolts
M8 sounds about right, but I'd have the shop use new ones, if possible. Will make removal later on down the road easier, if the need arises to do so... also assuming that one doesnt break upon removal!
Old Jul 30, 2009 | 11:50 AM
drewskie043's Avatar
whether you use stainless hardware or not, make sure the shop uses anti-seize lubricant. it's a paste like material you brush onto the threads and it prevents the nut and bolt from rusting together. i use it here at work all the time when running gensets and i swear by it. saves you lots of time in the future.
Old Aug 3, 2009 | 06:50 PM
biggriggs's Avatar
The ones that connect the downpipe to the cat-back at M10x1.50
I think that the ones that connect the mani to the dp are the same size, but those ones don't get much exposure, and don't rust up like the rear ones do.
-Riggs.
MJClemm
Oct 6, 2014 12:13 PM
ZIPPY02
Feb 14, 2013 09:47 AM
Joe Thomas
Jun 8, 2009 09:23 PM
wroeber_55
Jun 3, 2008 06:48 PM
24_48Fan
Mar 16, 2007 07:12 AM
