Power log vs PEM
I've been inquiring with ZZP since about mid-June on when they expect to be selling the PLOGs again. I just did a 2.5" DownPipe w/ High Flow cat (ver good mod) and really would like to finish my "exhaust" work with a PLOG (and I figure my $50 cat credit could go for a PLOG).
Every time I ask ZZP "We hope soon" is the answer. I'm gettin' ichy!! :-)
How much of a power difference between the plog or pem?
I'm going to contact zzp and see how long before they have plogs again. If its not anytime soon the pems it is as long as they'll still allow me to run a 3.4 pulley (after rockers of course)
I just found a plog for sale on club gp for $110
Is it ok to buy a used one?
Is it 304 stainless, or is it mild steel? I would NOT get the mild steel PLOG. These WILL leak- the 304 stainless may leak eventually, but it's not a guarantee.
Thank you. There not stainless so I'll pass. I only plan on doing what is needed to get the 3.4 pulley and won't go any farther and if its not much of a difference then I may just get the pems. Since the plogs tend to crack and leak, then at this point, their not worth the investment.
I can't make up my mind, lol. If I go PEM, do I need to get front and rear, or can I do just front?
PEMS in my opinion are a waste of money.
I disagree with PEMs being a waste of money. I went 13.13 in my Monte with a front PEM setup.
Our goal is around 300 crank horsepower and now were at 270 (according to the aeroforce scan gauge) so hopefully the plog, rockers and pulley will get us there.
Headers are awesome, but he won't even be near to needing them with his basic 3.4 setup
IMO, PEM's on the L67 are obsolete, and have been for a long time. First is the cost- usually when you find them; they're sold in sets (although I have seen places do just fronts)- but it seems like a lot of the used sets for sale come with both. Since the stock rear manifold is tubular, its not a restriction- and so half of the money you're spending is realistically for little to no extra gain.
Secondly with cost- look at the pricing; a single PEM seems to run like $50-80 used (brand new about $125); and a pair seems to run $75-125 (brand new about $150-190). A PLOG usually runs about $90-130 (brand new $180). Headers brand new start under $300; and used typically are all over the $200's depending on the brand (obviously much higher for some TOG big dogs or something like that). Plus with headers, you usually have some kind of downpipe connection included, so you save money on that too.
So a front PEM runs about 75% of the price of the PLOG with the same amount of labor to install- with less gains; why bother? May as well spend the extra $20 and get rid of the crappy front cast manifold (ever seen pics? its pretty bad inside). That's not even getting into the cost/hp ratio if you buy both PEM's- usually both PEM's + the price of a used DP = to headers, so that doesn't even make sense.
The argument for headers is you take the price of a used PLOG (say about $100) and the price of a used catless DP (also about $100)- and you're already more than 2/3 of the way to headers which are proven to have more of a power gain than a PLOG/3" DP. Sure install is worse with headers; but the difference in money is very small for the extra gain.
FWIW, I used to run a ZZP 3" catless DP and a mild steel (angled though) PLOG on my old GTP. I was very happy with the results, and never had cracking issues (just make sure you get the one with the angled primaries- not the ones that run straight up/down). However, I did not see the KR drop that some of my other college friends did who went straight to headers with similar setups.
Wow, now I really can't make up my mind, but thats for the awesome information. I'm still on the fence.
I don't know if I want to get involved with installing headers, they aren't much more but I'm a good mechanic and have a lift, torches, welder, ect...but I'm not good at fabricating.
Can you weld PLOGs if they crack since their not cast? If its repairable then it may be worth the investment.
Just because they've been around for a long time doesn't mean they're "obsolete"- they are better than stock for sure and have their advantages. While I don't have dyno numbers or before/after 1/4 mile trap speeds, I can say that I was able to pulley down AND add timing after adding my front PEM.
Thank you. After going over the pros and cons off all, were going to get a front pem. Since all we want is to get to a 3.4 pully and the PEMS with rockers will allow for it, then were going to get a pem, and if we don't like it, then we can always buy a plog or headers down the road.
Thank you for all the help everyone
Because the PEM is guaranteed to not fry your A/C condenser (like the PLOG did to my Regal) and isn't as crack prone, or because it's cheap and available. I went with the front PEM on my Monte because the PLOG killed my A/C on my Regal, and it cost me a condenser.
Maybe your motor mounts were worn out if the engine was moving that much? It really isn't that much bigger than the stock manifold.
The whole idea behind the PLOG was that the stock front manifold blows, ported or not- there are just some inherently bad areas. To me, its like trying to port out the downpipe to smooth flow around the u-bend. If you still have a nasty area; porting around it can only help so much. Being able to pick up a used PLOG for about the same as a ported manifold set is just icing on the cake.
Plus, headers are only a bit more money than a PEM set. Look at WBS- they want $190 for a set of PEM's brand new; when you can get headers (which include a downpipe) for under $100 more and have significantly more power gain.
Their high cost for relatively low gains is what made them obsolete; back in the day they were a great option - spend $150-200 for PEM's or $500-800+ for headers; today there are many more options that have closed that price gap.
I'll be honest, I've never installed headers on a 6th gen monte- just a 5th gen, and some GP's. But IMO, if you have all that stuff, installing headers will be cake, its not that big of a project. Lots of people have done it to 6th gens, so its not that big of a deal.
Your definition of "not that big of a deal" is a bit skewed. You drove across a few states to pick up an L67 to put in a '96 Monte Carlo and then rebuilt it in an apartment. That is off the charts big deal, so I can see where to you installing headers on a Wbody isn't a big deal. To the rest of us, it sucks.
I guess I'm confused what you actually had hitting- when I did the PLOG on my GTP, it didn't hit anything, and was nowhere near hitting anything. I've also never heard of this problem before (granted I'm only on Wbody forums)- any links to wbodys that have had this issue?
Again, like the track time, its not really useful data- obviously any kind of porting or such will show an improvement, but it doesn't really help compare vs a plog or vs stock since there is no real hard data there.
