Passing Emissions.
Old May 30, 2007 | 04:57 PM
86Ls's Avatar
Default Passing Emissions.
86' Monte Carlo.
Stock 305.
No cats on a 3 inch duals.
Will it pass Emissions with a good tune up?
If not I guess I'll give Jegs a call and order some High Flow cats...
Old May 30, 2007 | 05:09 PM
saluteTOme's Avatar
Default RE: Passing Emissions.
ORIGINAL: 86Ls
86' Monte Carlo.
Stock 305.
You will have to check with MO laws. I am not sure if MO is a strick emission state...chances are, you'll fail inspection. You may even fail on high flows....see if you can borrow some cats or buy some just to pass inspection and swap them back out.
Old May 30, 2007 | 05:54 PM
86Ls's Avatar
Thanks for the fast reply saluteTOme.
I brother works at Dobbs so he might be able to get me two good used cats for cheep.
Thanks again.
Old May 30, 2007 | 07:35 PM
wiz kidd's Avatar
you need to do emmissions on a 20 year old car??
i thought other than california canada was the stricktest...but anything over 20 years old doesn't need to do emmissions
Old May 30, 2007 | 08:54 PM
saluteTOme's Avatar
In at least NY and NJ, You need whatever came stock on the car of that year, which had a cat. In at least NJ, I am pretty sure you need a cat no matter what if your on the road except the pre 40's
Old May 30, 2007 | 10:34 PM
HaRvArDaLe's Avatar
in TN you have to put a car that is over 20 yrs old through emissions once......then you dont have to worry about it again and can do whatever you want to it
i just wish i had an old car to play with[:@]
Old May 30, 2007 | 10:54 PM
04 Intimidator's Avatar
Just put on a cat for a week and pull it back off.
Old May 31, 2007 | 07:58 AM
wiz kidd's Avatar
yah good idea, by a universal cat and put it on...then take it back off...if you dont have to do emmissions again...if you do then i would look into getting high flow cats
Old May 31, 2007 | 10:09 AM
rchurch's Avatar
I had a big bowl of red beans and rice for supper last night and been passing emissions ever since. Even my cats didn't help...they left the room running and I haven't seem them since.
Old May 31, 2007 | 07:56 PM
86Ls's Avatar
Rchurch. I know the feeling...
I had an idea to buy some old school FLEX PIPE and some used cats. Just fab up some mufflers and what not becuase here in Missouri they do not do a visual look over, just a performance. If we can make it look stock then I think we will be ok.
The only problem is that my wallet doesn't have alot of thoes things called bills.... Guess everyone goes through it.
LennyLeonard
Nov 15, 2016 06:02 PM
js1
Dec 30, 2009 04:27 PM
biggriggs
Nov 22, 2008 09:59 AM
04ss
Jul 4, 2008 07:27 PM
RedZed
May 11, 2008 09:45 AM
