Opinions On Next Mod?
Old May 9, 2012 | 07:59 PM
Originally Posted by 2003L67SS
thats exactly what you want with these, to shift that power up the range where you need it more, low rpm torque is literally on tap to the point of being too much and all they can do is burn the tires off, push the powerband upward and have better 60' and quarter mile times.
I agree to an extent. You don't want to lose too much power down low by going 3" without enough mods.
Old May 9, 2012 | 08:36 PM
S.O.G.'s Avatar
I have a couple of them BlackRainSS but for some reason it doesnt let me upload?? do i have to do anything to them to get them uploaded? it says file failed to upload idk why
Old May 9, 2012 | 10:33 PM
Old May 9, 2012 | 10:48 PM
Originally Posted by trewyn15
Since his Grand Prix is the Daytona it is supercharged, you may want to look into a top swap along with headers and a pulley drop (with supporting mods). If you drop a pulley you'll beat him no problem
Why does he have to look into a top swap if he has a stock supercharged 04 SS Monte ?
Originally Posted by SS Supercharged LA
I just recently bought a stock supercharged 04 SS Monte. Real excited to start working on it! My friends gotta 98 daytona edition gtp supercharged n doesn't think I can fix my Baby up to beat his! I need suggestions on what mods I should start with. I only have K&N CAI so far. Was thinkin of speed daddy headers next? Any tips or suggestions??
Old May 10, 2012 | 06:32 AM
TheMonteMan's Avatar
It retards your timing to dangerous levels, you don't have to worry about it with your electronic TB :p
im not worried about it at all. im just curious as to how exactly having your timing retarded would cause engine, and transmission damage?
Old May 10, 2012 | 08:46 AM
If your engine retards and delays your detonation at the correct time it can increase KR like crazy.
We all know what KR can do to these damn engines.
Old May 10, 2012 | 10:18 AM
i thought kr knock retard was the engine pulling degrees of timing to help prevent detonation sensed by the knock sensor. if the traction control is pulling timing out how exactly is it causing detonation, and knock retard? the only thing i can see happening would be a loss of power because the timing has been retarded. not trying to have a back, and forth with you here just trying to understand exactly how this engine/transmission damage is occurring due to timing being pulled when traction control is activating.
Old May 11, 2012 | 01:10 AM
S.O.G.'s Avatar
Old May 11, 2012 | 03:02 AM
2003L67SS's Avatar
running too little of timing can knock the balance of the engine off too much causing excessive bearing wear, and burn the rings up, it's not as bad as full blown predetonation though, that is primarily what we have to look out for, most people run the car hard with the traction control off so usually too little timing isn't an issue, just avoid driving the car hard with TCS on
Old May 11, 2012 | 08:29 AM
So there have actually been reported cases of engines breaking due to timing being pulled to such extremes while launching the car with traction control on?
