NEW 65mm throttle body
Old Jun 18, 2007 | 11:00 PM
rcohen's Avatar
Default NEW 65mm throttle body
http://www.60degreev6.com/store/inde...p;productId=24
Just bought this part, since I messed up the bone yarded TB i was boring out. I am wondering what measures Ill need to go to, in order to make it fit right. The problem is I have a spacer, and I am not sure the opening on the intake manifold is large enough for 65mm. Will I have to bore the manifold and the spacer? What about gasket material, will the RTV gasket maker stuff work?
Old Jun 19, 2007 | 10:32 AM
z34phoenix's Avatar
Default RE: NEW 65mm throttle body
yeah you'll prob need to bore the spacer and the intake manifold. the stock gaskets still might work, but you'll need to cut the hole a little bigger.
what are you doing with your old TB? i call dibs if your gonna get rid of it.
cangri_926
Mar 7, 2010 10:39 PM
dty2005
Oct 21, 2008 06:38 PM
3800monte
Mar 25, 2008 03:16 PM
big green dog
Jan 11, 2006 01:24 PM
