NEW 65mm throttle body
http://www.60degreev6.com/store/inde...p;productId=24
Just bought this part, since I messed up the bone yarded TB i was boring out. I am wondering what measures Ill need to go to, in order to make it fit right. The problem is I have a spacer, and I am not sure the opening on the intake manifold is large enough for 65mm. Will I have to bore the manifold and the spacer? What about gasket material, will the RTV gasket maker stuff work? |
RE: NEW 65mm throttle body
yeah you'll prob need to bore the spacer and the intake manifold. the stock gaskets still might work, but you'll need to cut the hole a little bigger.
what are you doing with your old TB? i call dibs if your gonna get rid of it. |
