Lovell Factor
Old Jan 13, 2019 | 12:53 PM
WolvenScout's Avatar
Default Lovell Factor
I was doing a little research on cylinder head porting, and thought I'd calculate the Lovell Factor of a stock 2000 Monte Carlo. I'm not 100% sure this is correct or not, but the Lovell Factor for a stock 2000 Monte Carlo appears to be 80.92 m/s at 6300 max RPM. If I raise the max RPM to 7000, I get an even higher Lovell Factor of 89.91 m/s. Just thought I'd share this info. (calculated using this Lovell Factor calculator (https://www.rbracing-rsr.com/lovellgascalc.html), and the specifications from a 2000-2005 Monte Carlo Service and Repair Manual)
Old Jan 14, 2019 | 06:55 AM
The problem is that these engines dont make any power up there, especially with a stock or smaller aftermarket cam. To make any useful power that high (7k shift points), you'd have to go with one of the biggest aftermarket cams (or have a custom cam made).
Certainly there have been some go that high or higher, but I dont see the benefit when you can make more than enough power for the trans and tires and still shift at a reasonable rpm.
joeykl66
Jun 25, 2013 04:57 PM
Shondu
Jun 1, 2013 03:02 PM
gr3g4554
Jun 6, 2011 05:58 PM
84monsterSS
Jun 30, 2010 01:48 PM
Code Red Monte
Jun 5, 2010 05:12 AM
