my buddies gtp build
Old Jun 3, 2010 | 12:48 AM
Code Red Monte's Avatar
Default my buddies gtp build
So this week (tuesday) the power steering pulley flew off the 900.00 car! well i said F it and wasnt fixing it till i do the build well tomo is tear down time!!!
this car has 202k on it
pulling everything off it going to paint a few parts (fiance picked out the color) plasma blue.
Going to fix a few leaks.
-oil pan etc
I have the following parts
-ported inlet outlet s/c (silencer holes filled)
-ported LIM
-ported heads are done and nice valve job
-machined snout with MPS 3.0
-Modded fuel rails
-65# injectors for e85
-Built trans with 3.29 gears 300mm input with 3250 stall
-Drag radials
-55 dry shot nitrous
-Wizaird
-NIC cam and lifters
-Ported 97 TB
-105# springs and retainers on the ported
Ported head specs (sorry no pics) :joke
lift intake exhaust
.200 130 105
.300 182 141
.400 211 152
.500 224 173
.600 232 176
:OMG
I should have this build complete in 3wks or less. depending on the headers and how long it takes them to get here.
there will be more pics posted tomo of the progress on the tear down.
Got the itch tonight (friday) and figured i could work on it for 30mins
MORE PICS added April 25th
hmm ported s/c
Old Jun 3, 2010 | 12:49 AM
UPDATE****MAY 4th*****
decided to pull the motor and clean it up and MAYBE put a nice healthy CAM in her!
Old Jun 3, 2010 | 12:50 AM
Supercharger pics. Polished myself
UPDATE ***MAY 31st***
NIC cam installed, p/p heads, built trans w/ 245mm trq converter w/ 3250 stall
Old Jun 3, 2010 | 12:54 AM
UPDATE **June 1st**
UPDATE**June 2nd**
Got it to fire tonight....primed the oil pump and then primed the fuel system and she fired!!! gotta tighten up a few things and time for TUNING!
Old Jun 3, 2010 | 01:14 AM
**UPDATE** June 2nd FIRED!
Old Jun 3, 2010 | 06:16 AM
IMO, the only thing I don't like is the semi-polished SC- I think I would've rather painted it or something- or at least kept polishing to get a uniform finish on it- including the snout.
Other than that- seems like a cool build.
Old Jun 3, 2010 | 09:37 AM
Well, I think it looks alot better than it did before.
But uh, got a question, whats this>>>:p
Old Jun 3, 2010 | 09:39 AM
Just a little humor there, I cant wait till I get mine (the GTP)
Old Jun 3, 2010 | 09:55 AM
MAMONTE's Avatar
Looks nice!
Old Jun 3, 2010 | 02:01 PM
TheMonteMan's Avatar
post a vid when you fire this thing up. i also agree with bumpin on the sc.
