HELP, INSTALLING DIRECT FIT CAT-23433
Old Dec 12, 2006 | 04:40 PM
rcohen's Avatar
Default HELP, INSTALLING DIRECT FIT CAT-23433
Hey guys, ordered a direct fit cat for my 3400 monte. It looks like it will fit nicely, but is gonna be a **********er to get the old one off. Any tips on how to rip the old one out? The simple unbolt, rebolt doesnt work due to all the rust.
Old Dec 12, 2006 | 04:48 PM
wiz kidd's Avatar
Default RE: HELP, INSTALLING DIRECT FIT CAT-23433
spray it with some kind of lubricant, let it sit for a while, try that, if it doesn't work then heat the bolts with a torch until they do come out
Old Dec 12, 2006 | 08:37 PM
rcohen's Avatar
thanks, will do. one of the bolts was stripped a tad, any hints on taking off a stripped bolt? Mind you, there is minimal room to work due to parts of the frame blocking most of the room needed for normal work. Thanks again!
Old Dec 13, 2006 | 12:29 AM
z34phoenix's Avatar
they have sockets made for removing stripped bolts. also switch between metric and SAE. and hammer the socket on if you have to! only use 6 point! the 12 will deff strip the bolts.
yep lastly use a torch or air chizel to cut the bolts out.
Old Dec 13, 2006 | 01:04 AM
rcohen's Avatar
thanks guys, nothing worse than having a beautiful car part sitting in your kitchen than having it in your kitchen and being unable to put it in! Ill try that 2morrow and let ya know how it goes
Old Mar 15, 2012 | 09:41 PM
Ron A's Avatar
Hope everything went smooth. workin under a car with a bunch of rusted bolts is no fun. I know this is an old post but thats probably good for my question. My question is hows the magnaflow 23433? is it holding up well? and any noticeable performance gains (u kno with the high flow cat and ubend delete?
Old Mar 15, 2012 | 11:36 PM
This thread is nearly 5.5 years old
You will notice a small gain in the butt dyno with both high flow cat and the ubend, but not much unless you do it with a downpipe or headers.
ShadowX760
Apr 23, 2013 09:25 PM
fastLS2001
Apr 5, 2012 08:45 AM
Scooby doo
Apr 1, 2010 08:59 PM
JuniorCar
Apr 19, 2009 09:11 AM
J_Bru_Ha_SS
Aug 4, 2006 03:50 PM
